It is currently Wed Aug 05, 2026 6:21 am
 Post subject: eVolve Questions
PostPosted: Thu Dec 01, 2011 3:11 pm
Does the charger have to be connected straight to the battery or can you connect it to the thru hull connector where the drive unit plugs in?
How will the upcoming solar panel be connected?
 Post subject: Re: eVolve Questions
PostPosted: Thu Dec 01, 2011 3:40 pm
The charger has to be plugged directly to the battery. The solar panel will have a cable and connect directly to the battery. I would imagine a new through hull fitting as well.
PostPosted: Thu Dec 01, 2011 4:04 pm
So there's three connectors on the battery?
1-Charger In
2-Solar Panel In
3-Output to Motor
PostPosted: Thu Dec 01, 2011 5:13 pm
Charger-in is the same as motor cable. You have to unplug the motor to charge. Solar is separate as is the port for the throttle, so yes... there are 3 ports in a v2.
