It is currently Tue Aug 04, 2026 4:43 am
 Post subject: Quest Pedal Problems
PostPosted: Sun Jul 16, 2006 9:38 am
Quest Pedals will not stay in track. Suggestions or fix to problem?? Have heard solution of putting another track on top of existing but also heard that Hobie may have a better fix for this problem. Thx
PostPosted: Sun Jul 16, 2006 3:55 pm
Mine does it too. I thought the elastic cord that holds them in might be stretching from opening and closing the hatch.
Waterman at Work - Kayak Fishing Photos, Video,Kayak Rigging - Blog
 Post subject: Better Solution?
PostPosted: Mon Jul 17, 2006 5:16 pm
Better Solution?
Seems that the width is an issue? The tracks are a little far apart? Adding the second track section does the trick I am told.
PostPosted: Mon Jul 17, 2006 6:29 pm
I haven't looked at it that closely, but I will try and determine what might be the cause. My Quest gets a lot of use in pretty demanding conditions. Salt water, UV sunlight working on any plastic or perhaps the rubber that might be in the stretch cords, sand from running in and out of the surf grinding the parts, it gets a good workout. The pedal popping out is not much of an issue, but might as well check it out. The only time I really notice it is when I load it upside down on the roof racks of my truck.
