It is currently Wed Aug 05, 2026 9:30 am
PostPosted: Mon Mar 05, 2012 2:24 am
Hi,
I'm a new and very happy owner of a Hobie Revolution - I assume it's a 2011 model.
Recently I purchased a set of turbo fins for the Revo. The label on the bag indicates #7206601 ("Threaded Mast") and #72065 ("Set Screw/Cotter pin").
When I removed the old masts from the Mirage, I noticed that they had a threaded end (male) joined to a threaded insert in the Mirage (female). Each of the masts of the standard fins were not locked with separate screws or cotter pins.
Now the problem is that the masts of the turbo fins did not come with a threaded end (despite the writing on the package). There is a hole for a cotter pin in one end and small clefts at the other end. Did I get the wrong (old) type of turbo fins? Is there a mistake in the packing/labelling of the content?
Thanks in advance for your help!
Greetings,
Dan
Copenhagen, Denmark
PostPosted: Mon Mar 05, 2012 11:05 am
Hobie Tech / Moderator
There was an error in the labeling or packaging of your kit. The mast should look just lilke the one you removed except longer. Let your dealer know so you can swap the masts out.
Brendan Castile
PostPosted: Mon Mar 05, 2012 3:53 pm
Hi Brendan,
Thanks for your prompt answer!
I will forward your answer to the local Danish dealer and ask for a swap to the threaded Turbo kit.
Greetings,
Dan
