It is currently Fri Aug 21, 2026 6:56 am
PostPosted: Mon Mar 04, 2013 8:42 am
I've got a Hobie Outback purchased new in 2006. I recently lost one of the plastic pedal crank caps that close off the pedal end of the MirageDrive crank assembly shaft. Per the latest parts guide, I ordered part # 81222101 to replace it, but the part does not fit and looks very different from the current cap remaining on the other shaft. Here's a photo, comparing the two caps. If anyone has the correct part #, I'd appreciate your help. Thanks.
PostPosted: Mon Mar 04, 2013 11:06 pm
These caps have evolved over the years. The cap is now screwed down (thus the hole in the top); the notch is for a small pedal bungee. They are probably the same part #. Ask your dealer to call Hobie Parts and inquire if any of the older versions are still available. 8)
PostPosted: Tue Mar 05, 2013 9:07 am
Older caps are not available. Adapt or glue the new version in its place.
