It is currently Tue Aug 04, 2026 9:37 pm
PostPosted: Fri May 24, 2013 10:23 am
First off I am very pleased with the performance and versatility of the Toqueedo kit I got many years ago.
I have the original Evolve motor (V1) mounted to fit in mirage drive well. I have the V2 battery upgrade from a recall - it came with a new charger and an adapter to fit the V1 (original) cable. Works great!
I would now like to installs this setup on a 2nd kayak (a tandem oasis) and want to be sure what I get will work correctly.
I see there is a #72022031 - EVOLVE v2 CABLE KIT (2ND HULL) listed for $175
Am am I correct in assuming this is all I need? That I would remove the battery adapter pigtail and that this cable would buckle up the the motor no problems? I further assume that the original controller would work and that I would also get a set of "through the hull" fittings?
Hopefully Matt or some Hobie tech will clarify
Yakaholic
PostPosted: Fri May 24, 2013 10:42 am
Yes - that is correct. The cable kit will let you use your eVolve on a 2nd hull easily.
Jacques Bernier
http://www.hobie.com/
