It is currently Tue Aug 04, 2026 3:17 pm
PostPosted: Thu May 28, 2015 4:04 pm
Is is okay to store a revo 13 on 2" PVC Schd 40 Pipe with the PVC as follows:
4 pieces each 18" long
2 pieces, one each in the long groves on the bottom, up front in the area of the mirage drive (basically centered with the center of the mirage drive)
2 pieces, one each in the long groves on the bottom, in the back with the center of the PVC pipe under the scupper hole.
the PVC pipes sit on perpindicular 2x4s - the bottom of the revo only touches air.
I see all the posts about using PVC on pro anglers, but what about these 4 short pieces on a revo in the above posistions.
Thansk
PostPosted: Fri May 29, 2015 8:12 am
Added Pics -
PostPosted: Fri May 29, 2015 12:50 pm
Seems to me, that it's not much different if you were to use the Hobie Cradles to store your kayak.....but if it was my kayak, I would use 2 lengths of PVC the were 7 to 8 feet long and mounted with cross boards spaced 5 feet apart.
This will really support the main body of the kayak as the longer PVC pipes will "sag and conform to a much longer area" .
I used this method when I had an Outback, but I used 2 7/8" OD schedule 40 pipes........when I upgraded to a PA-14, the only change I needed to make was a slight width adjustment, to fit the PA-14's bottom dimensions.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri May 29, 2015 2:36 pm
What hobbie cradels?
I"ve seen cradels for the AI, but not revo, are there Hobie cradles for the revo?
I"m hoping Hobie Admin will speak up here.
PostPosted: Fri May 29, 2015 9:39 pm
You are correct...Hobie does not make a cradle to fit the Revo.....brain freeze :oops: ...I was thinking of the PA cradle design when I replied.
However, the Hobie cradles are about 10-12" wide and I was comparing this to the 18" length of the PVC you are using.
Dr.SteelheadCatcher
Warrenton, OR
