It is currently Tue Aug 04, 2026 3:33 am
 Post subject: Bent Mast Rod
PostPosted: Mon Oct 02, 2006 1:16 pm
Any suggestions on the best way to straighten a bent mast rod? :cry:
I believe I struck a submerged Trident submarine...it took quite a shot. The mast appears to have pulled away at the top.
Thanks for any help !
Mike
"If I'm not at work, I'm Outback"
 Post subject: Bent
PostPosted: Mon Oct 02, 2006 2:08 pm
Take it to a vise and tap straight with a mallet. If you have to, with the drive mounted you can roll the boat on its side and pull on the mast to bend forward.
PostPosted: Sat Oct 07, 2006 9:29 am
Thanks Matt
Should I remove the mast first?
Mike
 Post subject: Mast
PostPosted: Sun Oct 08, 2006 9:32 am
If you want to do it in a vise...yes, remove the mast from the drive.
