It is currently Tue Aug 04, 2026 5:30 pm
 Post subject: Go Pro camara?
PostPosted: Sat Aug 09, 2014 5:13 pm
Hi I want to get a post for a go pro camara for my hobie
I already have a yakatack track on it
What will you recommend?
 Post subject: Re: Go Pro camara?
PostPosted: Sat Aug 09, 2014 7:10 pm
I've had 3 or 4 posts and poles for my gopro that I bought, none held up to the salt water. I ended up taking the nylon nut from one of them and attaching it to I think 1/2" PVC tubing then slipped that into the next size larger PVC so it telescopes. I then attached the universal swivel mount that came with the camera to the end. Worked like a champ and didn't corrode, but I unfortunately lost it a couple months ago in rough seas, I will likely make another one using the same design as it worked better than anything I had tried previously.
Hope this helps
PostPosted: Mon Aug 11, 2014 8:48 am
I am getting ready to make one out of the "Palmetto Kayaking" book/link.
Walmart: $15 telescoping Targus camera mount- Its easy to add Ram mount ball /etc to it - retracts/light weight....
