It is currently Fri Jun 19, 2026 7:00 am
 Post subject: Anchor trolley
PostPosted: Sat Aug 30, 2014 4:08 pm
Hi do I have to have an anchor trolley installed on my kayak to use an anchor or a stake pole
 Post subject: Re: Anchor trolley
PostPosted: Sun Aug 31, 2014 6:16 am
The simple answer is no....But it helps. I carry both a stake out pole and an anchor at times because of the varying depths I fish. Sometimes I stick the anchor pole through the scupper hole in front of me if I need to pinpoint a stop quickly because I saw baitfish scatter or birds diving. If I am planning to fish a planned out specific spot like a point in the marsh, I use the anchor trolley so I can position the kayak exactly how I want it (back to the wind, facing how I want to with respect to the current, etc). I have also used my anchor trolley to better control my drift chute when fishing offshore. Just my .02
Tight Lines
Pro Angler 14
2010 Nissan Titan Galaxy Black
PostPosted: Sun Aug 31, 2014 6:40 am
No, but it makes it easier to adjust your position where you are fishing. With the trolly, by sliding it, you can reposition and turn the kayak around 180 degrees if desired.
Dr.SteelheadCatcher
Warrenton, OR
