It is currently Fri Aug 21, 2026 4:54 am
PostPosted: Thu Oct 23, 2014 8:32 pm
Went out today and my mirage drive started feeling odd. Upon examination I found that one of the self-sealing nuts that tighten/loosen the cables had come off.
I've searched online but can't find out where to order a replacement nut. I think the part # is 8050111. I'd like to actually buy about 10 of them and "double nut" them to really secure them from coming loose.
I had a nut lying around the workbench that was the same size (7/16?) but I think the threads are a little different and I don't want to strip it to find out.
Any ideas whee I can buy some nuts?
Thanks!
PostPosted: Fri Oct 24, 2014 8:12 am
Part diagrams in the catalog page 45 shows it as 8050111 NUT 1/4-20 HX NYLOCK
These nuts should be changed out after some number of adjustments or when replacing chains and cables. The threads cut the nylon.
Hobie dealer: http://www.hobiecat.com/dealers/
PostPosted: Fri Oct 24, 2014 8:34 am
Thanks Matt. Much appreciated!
PostPosted: Fri Oct 24, 2014 10:40 am
Suggest ordering the Hobie hardware kit # 72020300......It contains 13 rigging items that includes, 12 pieces of the 1/4 x 20 nylock nuts.
I bought this kit four years ago and it is really handy to have on hand....you never know when you may need some stainless steel hardware or replace/add a line hanger or bungee hook.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Fri Oct 24, 2014 11:23 am
72020300 KAYAK RIGGING KIT - HARDWARE
