It is currently Tue Aug 04, 2026 2:14 pm
PostPosted: Tue Jan 13, 2015 1:24 pm
HOBIE INFLATABLE BELT PACK PFD (Hobie Cat. # S6780RG)...I have been using this PFD. The CO2 cylinder needs to be replaced.
The Hobie catalog does not specify if the PFD INFLATABLE REARM KIT (Hobie Cat. # S6779R) will fit the BELT PACK PFD.
Can anyone confirm that this REARM Kit CO2 cylinder fits the belt pack model?
Altho the CO2 cylinder I need to replace is salt corroded with the pn & specs all gone, inside the belt pack was the following info:
Halkey-Roberts Pro 3F V86160 manual inflator CO2 cylinder 24 grams.
I have seen 35 gram cylinders and others marked V86140.
Which is the correct replacement?
PA 14; 2012
Cape Fear River - NC
PostPosted: Tue Jan 13, 2015 3:19 pm
The (S6779R) is the correct replacement for the Hobie PFD.
