It is currently Tue Aug 04, 2026 2:15 pm
 Post subject: Grease on mirage drive
PostPosted: Tue Mar 24, 2015 5:59 pm
Notice grease coming out at the pins , is this normal? How does one replace the grease as I'm sure it's there for a reason. Image
PostPosted: Tue Mar 24, 2015 7:32 pm
Is probably just extra grease from the build. They use marine grease so it should hold up. When you rebuild the drive in a few thousand miles you will tear it all apart and can re-grease the shaft then.
"Third Normal Form"
  • Trampolines
  • Hobie cover
  • Davis Spar Fly
  • Kayakbob's Sprayskirts
  • Spine Board Hakas
PostPosted: Wed Mar 25, 2015 12:43 am
I shouldn't get overly concerned: I have had the same drive since my very first Hobie... probably sometime around 2006/7. It has had a hard life on the sea and is still going strong despite never having been greased since the day it was born. I don't run it into sand but I always wash it down after a trip and all I really do is give it an occasional squirt of WD40 or CRC spray lubricant - but that only because it seems like the right thing to do.
PostPosted: Tue Mar 31, 2015 12:58 pm
It's good to have enough grease on the main shaft so that it oozes out, especially if you use it in saltwater. It will help to keep the shaft sand and corrosion-free. I do a total tear-down and re-grease once a year, and always grease that shaft heavily. Just wipe off the excess once in a while if it becomes too much.
PostPosted: Tue Mar 31, 2015 3:05 pm
As the previous replies indicate, this is normal and wiping up with a paper or shop towel is all that's needed.
One thing that will "encourage the grease to leak/ooze out" is spraying the shaft bearing location with WD-40......it will soften up the grease and cause it to run making more of a mess.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Apr 02, 2015 5:02 pm
Thanks so much guys!
PostPosted: Thu Apr 30, 2015 10:57 am
I sprayed "LANOX" on my 2008 Mirage drive chain before first use use, and periodically, and it has never given a problem.
It has a Lanolin base so does not dry out like WD40 or CRC and it also gets under light rusting making it easier to remove.
Good for all Marine lubrication and anti corrosion metal protection.
http://www.inoxmx.com/applications-uses ... -for-inox/
Fair Skies, Max.
