It is currently Tue Aug 04, 2026 10:13 am
 Post subject: OUTBACK WITH H-RAIL
PostPosted: Thu Apr 02, 2015 2:49 pm
Just a shot in the dark here but has anybody ever retro fitted the PA HRAIL onto an outback? There are so cool and convenient i would to add some to my outback just wanted to see if its even possible. Thanks GUYS and GALS
 Post subject: Re: OUTBACK WITH H-RAIL
PostPosted: Thu Apr 02, 2015 4:41 pm
Kits coming... maybe summer or fall.
PostPosted: Mon May 25, 2015 9:48 am
Any further word on this? We are getting ready to invest in a pair of Outbacks, and that rail (and associated accessories) would be extremely useful. Would love to have for this summer...
PostPosted: Mon May 25, 2015 1:22 pm
Nothing new...
PostPosted: Fri Nov 06, 2015 12:16 pm
any update on this?
PostPosted: Fri Nov 06, 2015 3:09 pm
http://www.hobiecat.com/forums/viewtopic.php?f=78&t=54785
In stock.
H-Rail UPGRADE KITS
Update older model Pro Anglers to Longer H-Rail system or add 9” or 21” straight H-Rails on any boat, anywhere you like! Kits come with H-Rail tubes, end fittings and attachment hardware.
84625312 PA 12 H-RAIL UPGRADE KIT $149.00
84625314 PA 14 H-RAIL UPGRADE KIT $149.00
84626001 H-RAIL BOLT ON RAIL KIT 9” $19.99
84626101 H-RAIL BOLT ON RAIL KIT 21” $24.99
The PA upgrade kits are full length rails (pairs) the 9 and 21 inch kits are single rails.
PostPosted: Fri Nov 06, 2015 4:49 pm
Thanks. Bummer there isn't a universal kit. I have a 2015 outback and would love to put the h-rail on it.
PostPosted: Fri Nov 06, 2015 5:10 pm
Universal kits are:
You could adapt the Pro Angler kits as well... just not cut to fit as they come.
PostPosted: Fri Nov 20, 2015 9:07 am
I got a pair of the 9" H-Rails today. Set them out on an Outback for locations:
In the Tray along the seat:
Here is over the map pocket:
In front of the Rod Holder
PostPosted: Fri Nov 20, 2015 9:27 am
I'd put them on top so you don't lose the convenience of the molded in tubs.
PostPosted: Fri Nov 20, 2015 2:25 pm
Thinking out loud here. Are these strong enough to carry the weight of the outback? Lemme explain:
When you lift a Revo 11 or 13 overhead, the handles are pretty much at the balancing point so neither the bow nor stern feel weighed down; however in an Outback (even with the new matching rigid handles) the weight balance bow-stern is a bit off so you struggle more when loading it overhead.
Just curious.
PostPosted: Wed Mar 22, 2017 1:47 am
this is my Outback with H-Rail kit for PA14.
And this is my Revolution 13 with H-Rail kit 21"
PostPosted: Wed Mar 22, 2017 8:29 pm
If you are considering mounting a H-Bar on an Outback, be sure to locate it where it won't interfere with climbing back into the kayak if you get dumped out.
PostPosted: Fri May 12, 2017 5:22 pm
I've seen this on a couple of Outbacks and want to add it to mine. i am leaning towards using a 9" on the front as in the last picture by KeuKayak and the video here https://www.youtube.com/watch?v=QjfajhQ3qhM. I've also seen someone use a 21 inch rail and mounted it in front of the cup holder all the way to the front as in this video https://www.youtube.com/watch?v=eqVBkINDejQ. The last one may interfere with the built in rod holder, but it allows for a much cleaner fish finder install. Anyone tried either of these locations? Any suggestions on which may work better?
