It is currently Tue Aug 04, 2026 5:51 am
 Post subject: H-Crate in 2015 Outback
PostPosted: Sat May 30, 2015 9:15 am
I interested in knowing if the H-Crate installed in a 2015 Outback leaves enough room to fit the Hobie Heavy Duty or Beach cart. Anyone got photos to share, or ownership experience?
It's priced very attractive at $130 and I'm tempted to just order one =)
PostPosted: Fri Jun 05, 2015 4:31 am
bump.. anyone got an H-Crate and tried to fit any Hobie Cart while installed?
PostPosted: Fri Jun 05, 2015 6:44 am
I tried with HOBIE HVY DUTY PLUG-IN CART, but the H-Crate must be without the tackle bins. You can put only one tackle bin on the side of the rudder.
PostPosted: Fri Jun 05, 2015 6:52 am
No, but offhand looking at this photo, it appears to be a Outback Image
If you adjust the tie down straps so the H-crate is positioned farther aft, the cart would "plug in" and not interfere with the crate.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Sun Jun 14, 2015 9:01 pm
I bought the H-Crate last week and decided to share some observations for those wanting to use a Hobie cart with it.
1. I have the heavy duty cart and as you can see in the photos it puts some restrictions on what you can put in the front rod holders; basically you won't be putting rods w/ spinning reels in [not a problem for me]. A cart with bigger wheels make obstruct those rod holders more.
2. The H-Crate also limits how much your seat can recline before hitting it. I haven't had it on the water yet so not sure if this is even a real issue.. typically I fish with an inflatable life vest so it probably won't be for me.
