It is currently Tue Aug 04, 2026 6:29 am
PostPosted: Thu Oct 01, 2015 7:56 am
I recently acquired an older 06ish Hobie Adventure without a mirage drive. I was thinking I would be able to use the mirage drive from my 2015 Hobie Pro Angler but it will not fit due to the tabs. Is there anywhere I can buy an older mirage drive or make my newer mirage drive fit?
Thanks for your help.
PostPosted: Thu Oct 01, 2015 9:48 am
You have to remove the alignment pins to use on an older Mirage.
Instructions here: http://static.hobiecat.com/item_attachments/80010001_80013011_80013001z52.pdf
