It is currently Tue Aug 04, 2026 5:19 am
PostPosted: Sun Apr 17, 2016 1:01 pm
I think this XL live well is so expensive. Comments below:
- battery cover should remain in position when bungees is detached.
- the drain pipe must always be down the holes. Issue is wWhen you raise the drain pipe , that's side of the live well goes out of position and you have to wiggle the live well to align it back to drain pipe. Not major but I expect excellent design for the price.
- rod holder must have built in bungees.
- strap is too long . Must have a way to hide or fold it away neatly. Maybe I should just cut once I figured there's no reason to keep it that long for PA
- I think the handle should be h rail. Now I can see 400 dollars worth of live well....
If this is less than 300, I will probably just say all the good things about it
PostPosted: Tue Apr 19, 2016 10:10 am
Noted and passed along to engineering.
Thanks for the feedback!
PostPosted: Fri Jun 17, 2016 10:06 am
I agree. H-rail integration would be great as well.
2017 PA14 Dune
Lake St. Clair
St. Clair Flatts
St. Clair River and Channels
3x Michigan Master Angler Awards
