It is currently Tue Aug 04, 2026 3:35 am
 Post subject: Still not Fixed...
PostPosted: Wed Aug 31, 2016 3:45 pm
I have had the problem of the Mirage drive coming out of the Click And Go Mechanism. I thought the shaft was sliding left or right causing it to dis-engage. I tightened the cables hoping that would put more tension on the shaft. That did not work. Should I change out both Click and Go mechanisms???
 Post subject: Re: Still not Fixed...
PostPosted: Wed Aug 31, 2016 4:58 pm
There is lots of discussion on this. May be kicking one lever open while pedaling. May be a slight difference in the click and go. Some add lever keepers. There are many possibilities.
This one: http://www.hobiecat.com/forums/viewtopic.php?f=60&t=12867&p=71846#p71846
