It is currently Tue Aug 04, 2026 10:22 am
PostPosted: Mon Oct 03, 2016 8:41 am
Just bought a new Hobie Mirage Oasis and just looked at the hull and noticed two and one nickel size holes just in front of where the mirage drive are installed is this normal or a manufacturing/warranty issue?
picture 1: Image Admin edited link...
picture 2: Image Admin edited link...
found the answer: The white plugs are just small caps that Hobie install for cosmetic reasons over the insert that builds the structure to the front of the drive well - and the base of the sail / accessory mount.
PostPosted: Mon Oct 03, 2016 12:13 pm
These are caps over molded-in inserts. Two are related to drive well strength and the other farther forward is related to the accessory receiver.
PostPosted: Mon Oct 03, 2016 12:14 pm
Are the caps missing?
PostPosted: Mon Oct 03, 2016 12:23 pm
So out of the box the holes are visible or are there caps that get inserted?
PostPosted: Mon Oct 03, 2016 3:06 pm
The white caps are visible in your photos. This looks 100% stock standard / normal.
PostPosted: Mon Oct 03, 2016 5:25 pm
Thanks for the response.
cron
