It is currently Tue Aug 04, 2026 9:14 am
PostPosted: Fri Nov 18, 2016 8:32 am
I have a 2002 Outback with a broken chain cable on the drive. I'm debating whether to re-build or spend a little more and search for a used newer version drive.
Which versions/years of the pedal drives will fit this hull? Not sure if the drive well/drive designs are universal and compatible into newer model years.
Thanks.
PostPosted: Fri Nov 18, 2016 9:16 am
Any drive will work. Newer versions have alignment pins that can be cut off.
PostPosted: Fri Nov 18, 2016 9:35 am
Great - thanks.
