It is currently Tue Aug 04, 2026 9:14 am
PostPosted: Thu Dec 01, 2016 6:06 am
On page 25 of the 2017 Torqeedo Catalog (http://media.torqeedo.com/catalogs/torq ... 017-en.pdf) there is a new spare battery listed for the Ultralight series in addition to the standard battery. Here are the part numbers
Standard: Part no. 1416-00 (320Wh)
Larger Spare: Part no. 1417-00 (915 Wh) NEW
There are no additional details to be found elsewhere on the site. But the part number is different from the 915wh battery from the Travel 503/1003 series and hopefully is similar in format to the new Ultralight batteries (molded in carry handle and all connections on top and same side). This would be great - a clean format 915wh battery instead of using the longer Travel series battery with the unneccessary and unused pointy connection horns sticking out.
Peter
PostPosted: Fri Dec 02, 2016 8:14 pm
Here are some additional details from the helpful folks at Torqeedo:
This will be in the same form factor as the new USB Ultralight battery 1416-00, except more lithium cells packed into case will make it 4 lbs heavier. So weight of 11 lbs or so, dims 10 x10 x 6. Retail price $899.
Will look like this one but 915W power:
http://www.torqeedo.com/us/en-us/produc ... 16-00.html
I would recommend the 90W charger 1133-00.
This should be available in US Spring 2017, my guess is by mid-March but I do not have that confirmed.
Peter
