It is currently Tue Aug 04, 2026 2:47 am
PostPosted: Thu Mar 09, 2017 1:23 pm
I have a v2 drive that is making a squeaking noise when peddling. It looks to be because the right drum is rubbing up against the idler pulley. I'm not sure what I should adjust to create some separation so that the drum doesn't rub up against the idler pulley. Any suggestions?
PostPosted: Thu Mar 09, 2017 1:37 pm
Not sure about the rubbing you mentioned. Make sure the cable tension is correct and lubricate the areas where the cables touch the plastic. That should cure your squeek issue. I use Break Free CLP on both my Mirage drives and fish saltwater almost every weekend. I always inspect the drives after each outing for a bent shaft, the split rings and any fraying. I usually lubricate the drives once a month, but do rinse them off after every saltwater trip.
Steve Stubbs
USAF (retired)
SeaDek Fishing Team
Unfair Lures Pro Staff
Ziptailz Ambassador
2015 Pro Angler 14 - Papaya
2018 Compass - Sea Grass
PostPosted: Thu Mar 09, 2017 1:42 pm
Rubbing on the idler? This just at the end of a stroke?
PostPosted: Thu Mar 09, 2017 4:54 pm
Had the same on mine, just at the end of the stroke. Simply filed a round groove in the drum where it was rubbing on the idler.
Problem solved. My squeak was actually the pedals themselves. Just undo the nut, slide the pedal off and apply marine grease.
2021 Dune Hobie Lynx
PostPosted: Thu Mar 09, 2017 8:25 pm
Yes, mainly at the end of the stroke. I know it's not my foot rubbing on anything because I can replicate it when just moving the pedals out of the drive with my hands on dry land.
Edit: sorry maybe not exactly on the idler, but where it connects to the spine, closest to the pedals.
I'll take the suggestion given and try filing down the drum on the backside a little bit in order to create some space.
PostPosted: Fri Mar 10, 2017 9:33 am
And Lubrication!
You can also set the pedals one notch aft.
