It is currently Tue Aug 04, 2026 7:00 am
PostPosted: Mon Apr 17, 2017 9:48 am
Will the H-Bar install on a Revolution 13? Hobie seems very vague about what models it will work on.
2011 Oasis with Sail and AMA's
2011 Necky Looksha 14
PostPosted: Mon Apr 17, 2017 10:30 pm
I suggest that you try standing up in your Revolution before you invest in a H-Bar. It's kind of a stunt. Be prepared to end up in the water. If you want to do a lot of stand-up fishing, you should check out the Pro-Anglers.
PostPosted: Tue Apr 18, 2017 2:18 pm
So no one knows I take it, same response I get from all the dealers I've talked to. :shock:
PostPosted: Tue Apr 18, 2017 2:53 pm
Yes - you can put the adjustable H Bar on most boats (including Revo 13) We've made videos for the Outback - it basically fits the same on the Revo - use the provided short center bar and adjust the sides to fit.
Jacques Bernier
http://www.hobie.com/
PostPosted: Fri Apr 21, 2017 11:37 am
thanks for the info, no one (even Hobie) seemed to know for sure. I keep reading about how it fits most models but never a list of which models, very frustrating.
PostPosted: Tue Apr 25, 2017 11:11 am
It might be a good idea to invest in the sidekick ama kit (part number 72062101) if you plan on doing a good deal of standing on your Revo. These are especially useful when sight fishing, and allows you to concentrate on the fishing and not the balancing.
Howie Strech
PostPosted: Wed May 17, 2017 4:14 am
I have just done this and found the lower position can't be used as the adjustment holes line up with the sides of the kayak so you can't use the lowest setting, which is the one you want when standing. I got around this by not fully tightening the clamps so I can rotate the bar with two hands, that way you can get to the the buttons and remove it at the end of the day. I have yet to use it but I am sure it will work well.
Revolution 13 with sail & AMAs.
PostPosted: Mon May 22, 2017 3:00 am
Do you have any photos?
PostPosted: Mon May 22, 2017 1:11 pm
The center bar can manually rotate within the plastic clamps to allow you to access the lowest setting for your amas. This is normal.
Howie Strech
PostPosted: Mon May 22, 2017 3:53 pm
We will have another look. Seems... if you drilled a hole 90 degrees from the existing one for the spring button... you could get the high position with the button facing forward. middle "button up" and low with "button aft".
PostPosted: Sat Jun 24, 2017 2:24 am
Works great
PostPosted: Thu Jun 29, 2017 12:56 pm
Awesome, thanks for the picture, that helps a lot. Have you tried out the H-Bar without the AMA's?
PostPosted: Fri Jun 30, 2017 6:21 am
Nope, and I don't think I will. It's going to -7c (19F) in the morning so I don't want to get wet :shock:
