It is currently Tue Aug 04, 2026 7:44 am
PostPosted: Fri May 05, 2017 11:08 pm
The Mirage Drive will do a few things that aren't in the operator's manual. In part 1 of this series, we look at shallow water operation. It's unique in that the Mirage Drive / MD 180 is the only pedal system that can operate in skinny waters. How shallow? About 12" with the Revolution series and 14" with the Outback.
The first thing to get comfortable with is the "flutter" stroke. As the following composite pic shows, this is where the fins are operated within a small arc next to the hull:
There are two types of flutter stroke. The basic flutter is where one foot is extended all the way forward and the other foot is kept close; you move the fins mostly with your ankles. It's quick to employ but tiring after awhile. With the advanced flutter, one pedal is adjusted all the way forward and the other moved back a couple of notches (depending on leg length). It takes a moment to set up, but is much more comfortable for extended use. The following picture shows the basic flutter on the right side and the advanced flutter on the left. Notice the difference in the pedal positions, given that the fins, in both cases, are in a horizontal position. Also, look closely at the drums on the left side.
The other thing we need to do is enable the rudder to operate in shallow water without dragging. My solution is to buy and extra sailing rudder for about $30 and shorten it so it's a little shorter than the small rudder. While shorter, it has much better authority than the small rudder -- in fact, pretty darned close to the large rudder:
Image Image
In order to determine the actual depth I marked the paddle blade and used it as a depth finder so to speak.
Put it all together and you can put right along. In the next picture, the fins are licking the bottom using the "Phat Albert" rudder and the advanced flutter stroke. Nothing like some roiled black mud to witness your strokes!
Here's a small gallery of some of the cool adventures you might encounter:
The Mirage Drive is made for this -- don't hesitate to take advantage of it if you have the opportunity!
What about sub surface hazards? Sounds like an excellent topic for part 2. 8)
PostPosted: Sat May 06, 2017 4:42 am
I reckon backing up to unsnag trolled lures would be a good use of reverse.
PostPosted: Sat May 06, 2017 8:33 am
Really good advise roadrunner. We find shallow peddling (with the pedals adjusted) is actually pretty efficient in unknown waters, and safer. We still put the bungy on the drive so ehen you take your feet off the fins fold against the hull in a safe position. You can still pedal just fine even with the bungy on the pedal arm.
We now have a TI that is our only family boat that we use for both kayaking and sailing (about 50/50).
The TI has a swing down rudder that is very long and big (needed for sailing mode). However this becomes a problem in shallow water kayaking. It's not really an option to cut the bottom off the rudder on a TI so what we do in shallow water kayaking is raise the rudder up so it is angled up about 15 degrees so just the tip of the leading edge of the rudder is submerged. The boat still steers fairly ok (kayak mode, or trying to sail out of mud bogs and accidental low tide shallows). It obviously doesn't work well enough for big sailing in big wind, but in a pinch when kayaking it helps.
Be careful though, with the rudder pointed straight back (not angled up), the force to turn the rudder is greater than the rudder strings can withstand (without extended rudder arms), we found that one out the hard way (lol).
All just my opinions
FE
