It is currently Tue Aug 04, 2026 5:46 am
PostPosted: Mon Jun 05, 2017 6:28 am
Hello folks.
I'm trying to upgrade a V1 drive...
this is the drive i'm trying to upgrade to GT.
now i've been reading and searching the forums and the parts list i've found are as follows:
HStrech wrote:
Sounds like you have a V1 drive (plastic drum, plastic spine, sprocket/mast connection is a set screw). To upgrade to V2 sprocket, choose one of the following, plus fin of choice:
If you want to upgrade your V1 drum to GT, use the following kit and GT sprocket update kit and fin preferred:
81171002
DRUM UPDATE KIT V1 TO GT
81129023
GT SPROCKET / MAST KIT STD
US$ 86.99
now for questions:
81171002 DRUM UPDATE KIT V1 TO GT
the drum here does not seem like they are GT with the roller bearings in them?
when i upgraded my V2 to GT, i used this
http://www.austinkayak.com/products/164 ... rings.html
and it was the right one...
can i use the grey drum on a V1 spine?
and if so, then the parts i need to upgrade a V1 to a GT would be
2x Drum
[img]data:image/jpeg;base64,/9j/4AAQSkZJRgABAQAAAQABAAD/2wCEAAkGBxMTEhUTEhMVFRMVFRUXFRUVFQ8VFRcXFRUWFxUXFRUYHSghGBolGxUVITEhJSkrLi4uFx8zODMtNygtLisBCgoKDQ0OFQ8PFSsZFRkrKy0rKysrLS0rKysrKy0rLTcrLSsrNy0tLS0rKy03LS03Ky0tLS03KysrNysrLSsrK//AABEIAOEA4QMBIgACEQEDEQH/xAAbAAEAAgMBAQAAAAAAAAAAAAAABQYCAwQBB//EAD8QAAIBAgIGBwYFAwMEAwAAAAABAgMRBCEFBhIxQVFhcYGRobHBEyIyUmLRQoLC4fAUI3KSsvEzQ6LSBxYk/8QAFgEBAQEAAAAAAAAAAAAAAAAAAAEC/8QAGhEBAQEBAQEBAAAAAAAAAAAAAAERAjFBIf/aAAwDAQACEQMRAD8A+4gAAAAAAAAAADyUkldtJLe3kiHxmslCGSbm/o3f6nl3XAmQU3Fa2VX8EIxXN3k/ReBG19L15b6sux7K/wDGxNH0Q1yrRW+SXaj5gsRt/j2+fvbXfmexhyTfUnJvsWbJo+nxqxe6SfajM+V05ptrjHfFpxkuV4tJo3U60obpyjbjtOPihqvpwPn9DTeIjuqtr6rS8XmSeG1smv8AqU4vpi3F9zuXUW0EZgtPUKmW1sy5Ty8dz7yTKAAAAAAAAAAAAAAAAAAAAADyckldtJLe3kiu6T1qhG8aS238zyj2cWc2vdadoQi8ntNr5rWyZSo4gzaqYx2kqlZ3qSbXCO6K6ka8HQdScYRteTsr7i16K1bwsqUJzpxqSlCLcpXe9X935bdBXNJUv6XE2pvKDjKN227NJ2b3viudhgk8TqjUjFyhWU5LPYcNlPoUr5Pruc+q+Gp1K1qiTSi5KL3N3W9cbEvPW6lsXUZbdvhdrX6Zcio0q8oyUotqSzusncfguOtGiaUqTqqEY1IWamkk2rpOLa3pp2tzsc2pTj/cX48rc9njbt9CBxmk6tVJVJuSXD3Uu1JZ9pywqtO6bTXFNp940WrXXDwtTnZe0UnFPi4OLck+avsvr6zLVnRlGdLbnThOW0170VK1uCT3FUq4iUneUnJ85Nt97OvR+lalG/s5K0t6aur8xo6tZNE06FVOklGFRNuCyjGUWs4rgmnu3ZG3CatVakFNTjC6uk1KTfXZq3iRONxc6snKpK78EuSXBFp0VrLSVKKqNxnFJNWbvbJNWH4KtUoyjKUJq0ouzW9c8nyaafaduj9MVaOUZXj8srtdnLsMHU/qsV8qqSS6Ukrd9kSOntVVCjKrQnU9pTi5bMpbUJqKvKLjbJ2Ts1YgmtH6w0qlk3sS5S3dkt3kS58llikldlw1H0rKrGUHdxj8LfLc11ZrxLKYtQANIAAAAAAAAAAAAAAAAqevCzpP/P8ASUfHUrO63PNeqL3rv/2vz/pKniaO1FrtXWYvqstF6016MPZxcXFbtpXt1O5x18bKpNzm7yk7tkZKRj7YCVjVM1VIuOINka4Ekqh7tkfGsbI1gOuLsg5nKq546gHT7Q99qcftjXOuBJYbHOnOM474u65EtpbXeU6ThGmo7SalLabyeTsrZeJTquJOGpXuB2Kcqs1FcXb9z6PqXTUZuK3Kn+qJSdWMJvqPjlH1fp3l81Vj/dl/h+pD6LSADaAAAAAAAAAAAAAAAAKpr5Kypfn/AElapy2ll1osevyyp/n/AElOwNWzce1GL6rh05S2WprdLf0S/f0ZEOsW3HYZVIOL3SWT5Pg+8peMwtSm7Ti10/hfUxFbVXM1iTnw2EqT+CEpdKWXfuJOhq5VfxOMe1yfhl4gcyxBksSStLVqP4qkn1RS87nVHVunx9p2tL0Ag44k9/qSc/8ArlL6+yUfsaaurUeE5rrUX9gIl4g0VMQSFfV2qvhlGXXeL+3iRGLwNWHxwklzteP+pZAa6la5lhKbnOMFvbsc5aNU9HNf3ZK11aF+ne/50gWTCUFCKit0VZfcntUnec39K8yAxlTZjZb9y9WTmpKzn1LzERawAbQAAAAAAAAAAAAAAABVNfN1L8/6ShzdnfkXzXt5Uvz/AKSiVzF9VJUKl117us3JELhMRbLtRNUZqSUl2kGSRlkst75cF1v0DdllveS9WZQjYDzPnboWQ9iuXeZnll09yKPHSXJHmxbc2vLuMu9vlfd1ntv5w7gNTbW9dq+x75Gyxpl7rXKTs+t7n6Aav6Gnfa9nC/PZjfyO6lGyuY04XZrxteyy45L1IrkxNTal0LJFs1MXx9UfNlMhIuepn4+qPmyz1FoABtAAAAAAAAAAAAAAPGz0qetGl3K9Gk8t05Lj9K6OZLcERrfpeNSolF3jBNJ8297XRu7iq16tyTqaJUs25XODFaJlHOL2ujiZVG1K1ndEpoXSC29l7pbushMRE5qVZxknxTuB9BqcOh+f8Rmmc2j8QqlNS5rM2PLpj5df3INu0e9f/BjCS4W7DK5Qj/N4uufmeWXJdyFlyXgB7dfy5oxLu4x4uS8Hd+CPalZbkrvkv5kbMLQzvLe9/JLkgM69XYj0yIPEYq76NyMdNaQvJ2eSyXqQFTGO+QE/TqZ7y36nY+KqOLfxpJdaeS8z5/gcPVnmslzJrC4KUM9rwA+tAgtXtMe0Sp1H763P5l9ydNyoAAADw9AAAAAAABhWqqMXKTsoptvoQETrJpX2UNmD/uT3fSuMvRfsU5ZZLfxfL9zZjMW6k5VZb27RXJfhRglaPXvMW6rCru3u5yUcf72zLNeKN2IqEDOpasul2IN+n8Gl767fRlarRzLnj1tUH0LyKfVZYqe1WxVm4Pc9xZSh6Pq7Mk+TLzSqbUVJcUAnTjvtbpWXkc2072g5PpezbvyN2JbtZcbLvyK9rbrA8JGEKcU5zTab3Risr24tvyYROWqcX3JP1NkKSe9yfbZeFijaD12qSqKNazi2k7JJq+V1YvzWd+dwMowSySSXQY46tsUnb4pZI2QjdpERp3EXk0t0cl18QK3pCoNC4T2k7cFv+xy46oWLU2lk5dL8BVTlRxpRSSV/LqNXtJPO78Dk0nU/uW5W/c34esrIiM4V2pJS47pLdf7l51d0p7WOzJ+/HxXPrKLVp7UWn/wzq0NjpQkpL4ouzXPn3oso+kg10KqnFSW5pNGw2gDw9AAAAAABXtcMXanGkt83d/4x+7t3MsJRdP4nbxE3wh7q/Lv8bmeqRHJXlbhHze/wMqzMKO6/F595jNmWnNiNxAYuVpp8mvMnqxC4+mUTdLOnJdfiUmuy5aPleL6k/Apmk3apNfU/HMDLDzzLdoDE3hs8UUSFYsOr2IftOzMC11Hu615lb1z0BLExjOnb2kLrZbspRedk+DT82T06mdulHixCCKDq/qfXdVSrR9nBNN3cW3Z3skm99j6VLcut+hzQro3bV0ut+gVt9psxlPkrLrKvpGp+/W95MacxOwoR7X1rh4lVxWLWYRE4yp7xe9VKVqK6l4nz6o9qZ9IwHuYe/R6fuKqMr1Nqo30s6aTOKlHM7aX2/cI7qcro5k9mouUsn18DZRZhjI3WW9ehFXnVPF3hKm98c11Pf4+ZPlC1YxlqtN3+LJ9Ty87F9N8pQAFQAAAAAYVamzFye5JvuVz5rVk2m3vk8+13Zf8ATc7UKr+hrvy9T5+/w9foZ6WM7muRsZrmZVzVThxECQqI4q4G3ANZLmrdpBac0DUnUcqbir2vtXy6iQU2jRpHSNbY/tbO19eeXQ+fWUcNLQriltSV+OzEk9HU4wkklvfvPiyLjiqrivaO8uOzkt/2N2DrtS3X7wix1YXtzR7TwS4ihFpXe/idVfYpw9pXlsxte19lJPdtPm+S/YitccIjooU0muS8yNwWncJVlsQkr8LOcW+ra3+JKSjstZ3i9z9H0gc2laMZrZfXfK6fQVzF6Bk77M434bUX6E9j6K2s+Kut5C6VeIUV/T2cr5qTW7ou0iojcDqzW21tuGTveN8+yxbtIWhSUOOV/wCdxz6Pr1I017Rp1Le9s5K/JHLiqjk7sDymjopGimb6a6e4K6IGytDI1xM6k8gPdEztl8ssvQ+n0am1FS5pPvVz5Vo9+/LsZ9L0PO9Gm/pt3ZeheUrsPQDSAAAAACM1kf8A+ap+X/dEob3rtL9rDC+HqdSfdJN+RQHvXaY69WNpjIyR40RXPURwYkkahH4lBHHM5qkTqaNM0UcNWJ0aKheXaeSidWErrcklbPpYFicPhT3OUb9V0VD/AOR68pVYRd9mzl0OV7PuVu8uFKSnBPsfWcmmtERxUUpZTW5qyd+LXNPiiK+T3aaa333n2HR2Ic8PTlL4rQv17Ofn4FZwOolpp1JOST3NKK/M7vIt1OlkoR3LxYK0aTXuxfX/ADyIyCz7/L/gkNK1LyUV+FePE4kyozRxVd52JnFUeYG2mdFNnPSOimFbomNRmaNNZhGWBfvvqPpGr3/Qh+b/AHM+a4D42fS9Ar+xD83+5lno7z0A0gAAAAA0Y+ntU5xXGEl3pnzafqfUD5xpTD7FScOUnbqvl4WM9LGqJ6zCnMzuZVqqIj8QiSqHDXQRHs1zMqzNEqhRprSOeFRp3W9GyszRFXdiiwaKxvvLZ470yeyfQRGgMFZX4vyJPHyT91cCDbGHSeYnEKCst74kfhp7M+hnVioXXSvIDgmzFnlz1geVJWRyN3YxFY10mB2Uzpijmpfz0OiDA3XNFU2NmjEVMgN+ilm302Pp2jIWpQX0rxV/U+e6Aw204x+Zrxdj6WkXkoegGkAAAAAAqGuGGtUU1uks+uOT8Ldxbzk0ngI1obMss7p8mSwfNk7O3cbYyO3S+i5UZbMs0801ua9GRqfgZVtqM4q50zkcldgR2JI2pUsSGJZFYgDZCdy34jValTw9Gt7VyqVdl7K2dizW07ccslcpFGF2XLQ2HezFNvjvvknm7LgFd0Zxpwu3a+SOazefM36RxcZQVJRWUtpz3vJNKK5LN9pwQk1uCNtai3muBuwtZSWTzj5HBiZya3s7MFpSMaMaEqa2ozlKNS/CT95NWz7+C5BW/E6Ppqi6sZvbU1GcHa1pXcXHu8yCxGJ4E1jKO1FrtRVal72YR653ZvpM5kjfSfp1doHfT/nr5G9M5abNjkBslUNcYObsu0w3uy4li0RoZ1fcSVrZt3St0tAS2qOEvLa4RXi8l6luOTRmBVGGynd727WuzrNSIAAoAAAAAAAAj9N4D21NpfEs49fFdv2PnuJptPpW9H1Iq+tGid9aC/zX6urn38zNn1VNnUOOvVOrF4eX4c+j7ENiI1N2y+4g1YmucWy2ySwuiZyd5ZLp+xY9F6Eu7Qi5S73+yCoLRWin8UlZcuLLlovRlSorQj0OTyS7eZN6N1ZjHOq7v5Vu7ZcewsFOmopKKSS3JZIuJqt4XVCCzqTbf0pLxZ3w1cw6/A31yl6MlwXIiGqas4d/ha6pP1InH6kp50p2fBSX6l9i3gZDXzvEYKpSyqRafB8H1PcQOltGtvbh2rj2H1+rSUk4ySae9NJor2kdWU7youz+SW7slw7SYr5Vmt6M6cvJIs+kdGZ7NSDjLuf2aIPFaKnHOPvLo39xBjCZm6hxqFS9tl9zJPAaOk2nPu+4HXorCtu73vcfSdDYH2VNJ/E85ei7PuROrOibWqSX+K5/V1cu/kWUsgAA0gAAAAAAAAAAAaAAgNK6uRneVK0ZfL+F9Xy+RW56JrJ2dGd+hXXesj6GDN5XVW0Zqy8pVnb6Y5vtfDsLJh8PGC2YRUV0evM2hlkQABQAAAAAAABpxWFhUWzOKkun0fBla0jqzJXlSe0vlllLsfHtLWCWD5/T0XWbt7Gd+lNLveRZNF6vxhaVS0pfKvhX/sTgJOV0ABpAAAAAAAAAAAAAAAAHjB6AAYAAAADwAD0AAAAAPAACPQAPAAB6AAPD0AAAAP/Z[/img]
1x IDLER PULLEY
[img]data:image/jpeg;base64,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[/img]
2x sprocket
[img]data:image/jpeg;base64,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[/img]
thanks in advance.
Al
PostPosted: Mon Jun 05, 2017 6:31 am
sorry, the image links on bottom are all messed up.
so,
will these parts work with a V1 spine?
Hobie Mirage Drive Drum GT with Bearings
Hobie Mirage Idler Pulley for Mirage Drive GT
http://www.austinkayak.com/products/169 ... ve-GT.html
Hobie Mirage Drive GT Replacement Sprocket with Bearings
http://www.austinkayak.com/products/169 ... rings.html
thanks in advance.
Al
PostPosted: Mon Jun 05, 2017 7:21 am
Be aware the shafts will probably be worn, if you do decide to keep them flip them over 180 degrees as they will be worn one side. Also are the fins worn?
I did this upgrade, wouldn't choose to do it again. Are you likely to be upgrading the whole kayak in the near future?
All parts will fit any spine.
PostPosted: Mon Jun 05, 2017 7:25 am
81171002
has the right drums (grey ones) even if not clear in photo shown
Dont forget different chains required, hence the kit rather than just drums
PostPosted: Mon Jun 05, 2017 9:47 am
WAVERIDER wrote:
81171002
thanks, noted about the shafts.
it's not really my kayak but rather doing this as a "gift" for a friend's son so he can go circles around his dad... hahaha
actually, he was quite impressive on a recent project and it is a gift for him.
the part you've linked, 81171002
everywhere it shows black drums... so they are the GT drums?
thanks.
Al
