It is currently Tue Aug 04, 2026 7:09 am
PostPosted: Sat Jun 10, 2017 12:29 pm
Are other brands besides Lowrance and Hummingbird adaptable to the built-in transducer mount on the Outback hull?
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
PostPosted: Mon Jun 12, 2017 8:52 am
For other brands aside from Lowrance and Humminbird, BerleyPro might have a mounting solution that adapts to Hobie kayaks. If you're thinking of going Humminbird over Lowrance, be aware that some transducers may not fit inside the cavity, and performance of Humminbird side imaging transducers may be compromised by housing them inside the cavity (don't have much experience with Humminbird side imaging on Hobies). I have a running list going if you have questions about the fit on most of Lowrance and Humminbird transducers on Hobies, and the customer service line at Humminbird should be able to answer questions on specific transducer dimensions if you need them.
Howie Strech
PostPosted: Mon Jun 12, 2017 9:03 am
Thanks. I'm giving the Hook 4 a serious look.
PostPosted: Mon Jun 12, 2017 9:15 am
That unit is plug and play with our Lowrance Ready feature.
Howie Strech
PostPosted: Mon Jun 12, 2017 10:08 am
Do you know the difference between the 4x and the 4 Hook models?
PostPosted: Mon Jun 12, 2017 11:01 am
Hook 4 has built-in gps and Hook 4x does not.
Howie Strech
