It is currently Tue Aug 04, 2026 2:16 am
PostPosted: Fri Jun 30, 2017 8:34 am
I just purchased a 2000 Hobie Mirage Oasis and can't find the hull ID number. I've looked everywhere using a bright light at an angle and a magnifying glass. The FAQ says it should be on the right underside near the rear. Here is a photo of the starboard side rear.
If you own this model, can you verify the location of the number? Thank you!
PostPosted: Sat Jul 01, 2017 4:58 am
I was able to get the hull ID number from the DMV. I will engrave it where is should be and call it good. :)
