It is currently Tue Aug 04, 2026 3:27 am
 Post subject: Rudder adjstment
PostPosted: Mon Jul 10, 2017 12:09 pm
Hi all, Just got back from 1st trip in new Outback....Loved it!! The only thing I am curious about is if there is any adjustment for the tension of the rudder steering. It's quite stiff and maybe it will loosen over tie, but kind of difficult for now. The dealer is 90 minutes away so if there is anything simple I would attempt it. Thanks for any hep!!
PostPosted: Mon Jul 10, 2017 1:23 pm
Hello all....Is there a friction, or tension adjustment on the newer outbacks? The entire rudder system works great except it's rather stiff even up out of the water on the trailer. Thanks for any help.
PostPosted: Mon Jul 10, 2017 4:30 pm
Yes, you can loosen the rudder lines at the rudder itself.
https://www.hobie.com/support/mirage-outback/
https://static.hobiecat.com/digital_assets/Twist-n-Stow_Repair_Manual.pdf (Page 8)
PostPosted: Mon Jul 10, 2017 7:33 pm
Thank you Matt!! I'll check that out
