It is currently Tue Aug 04, 2026 6:58 am
PostPosted: Mon Sep 11, 2017 10:36 am
Hey Hobie Friends,
I just received a Hobie Outback 2008 from some family and discovered that their is a crack in the hull. It looks like two separate cracks underneath where the mast support is. The hull looks slightly bulged out as well. The center support on the inside is cracked which is probably causing the hull crack and bulging. I am afraid that just repairing the cracks will lead to repeat occurrences. Is this fixable?
Crack in hull:
https://drive.google.com/open?id=0Bx-LU ... TEwNnR3NEk
https://drive.google.com/open?id=0Bx-LU ... zk2dlpCM0E
https://drive.google.com/open?id=0Bx-LU ... FVjVDVmWWM
https://drive.google.com/open?id=0Bx-LU ... XJLQ1p3T2s
Bulge:
Mast Crack:
https://drive.google.com/open?id=0Bx-LU ... zFHQUQ4OWM
https://drive.google.com/open?id=0Bx-LU ... 1gyWnBRZ3c
https://drive.google.com/open?id=0Bx-LU ... ERBbmktVms
PostPosted: Mon Sep 11, 2017 2:30 pm
That appears to have been weld / repaired in the past. The bottom of the boat should see a brass fitting exposed where the white spec is. The inside looks burnt.
PostPosted: Thu Sep 14, 2017 7:55 am
Do you think just the bottom had a new piece melted to it to cover a crack? I can re melt the plastic on the bottom to cover some of those cracks. I am worried about the center support. I do not like the crack in it and what looks like the bottom moving away from the normal position. I am not sure how to fix that. Also, I am not sure that the kayak is actually leaking. I might test it this weekend.
PostPosted: Thu Sep 14, 2017 8:23 am
That is an original Outback from Early the 2000's - that's the way we made the early mast supports. You could weld over yes. I wouldn't recommend using the mast receiver for a sail kit. It's likely not strong enough.
Jacques Bernier
http://www.hobie.com/
