It is currently Sat Jul 04, 2026 2:30 am
 Post subject: Sidekicks purpose
PostPosted: Sun Oct 29, 2017 12:24 am
I had purchased them to keep myself from flipping. I was wondering if these things will keep me from flipping. I heard that if your kayak fills up with water and then tilts to one side that all the water in the kayak will shift to one side and the kayak will flip over even with the sidekicks. Is this true?
I was wondering if I kept the sidekicks in the down position if that would reduce the chances of flipping since it would keep the kayak more level.
Anyone out there willing to share their knowledge and experience with sidekicks?
 Post subject: Re: Sidekicks purpose
PostPosted: Mon Oct 30, 2017 9:11 am
You'd be surprised at the stability the Sidekick Ama Kit adds. There's three different height positions you can set the floats to. In the low position, the floats skim the water and greatly enhance initial stability...when cruising, set them so they are off the water and engage only for secondary stability (side to side roll) support.
Howie Strech
Parts & Accessories Product Manager
PostPosted: Mon Oct 30, 2017 9:27 am
There should be no water in the hull to shift and make it unstable. The cockpit drains easily.
PostPosted: Tue Oct 31, 2017 2:47 pm
Both me and my wife are older and overweight when we first started kayaking our biggest concern was flipping when in surf or boat wakes. Just in case we put our kayaks in our heated pool and practiced getting back into the kayak. At first neither of us could re-enter a flipped kayak, after practicing we figured it out. Flipping your kayak is something you should always be prepared for and practiced once in a while. Always lash everything down. We got into kayak sailing which turned out to be our favorite pastime. Yea you flip once in a while, but it's no big deal at all. All the Hobie kayaks are sit on top kayaks, meaning the hull is sealed and can't fill with water like a sit inside kayak would. After 3-4 outings you develop the balance needed to keep from flipping, so you don't even think about it, just go out and have fun, if you flip it's no big deal, just make sure you practiced getting back on the kayak.
One other pointer is if you are in surf or in an area with boat wakes, having your double ended paddle in your hands it can be used to stabilize the boat, especially in surf.
I've seen other kayak sailers use the sidekick pontoons, (we call them training wheels lol)
We never bothered with them, yea we flipped often, (especially playing in offshore surf), it's no big deal, just like riding a horse.
Hope this helps
PostPosted: Tue Oct 31, 2017 10:28 pm
Unfortunately I know quite a bit about all the different materials (I'm a plastics expert), and also know quite a bit about all the different bonding methods used today in industry and have the scars to prove it, (if you touch dielectric welders during operation it cooks you inside, happens a lot when designing and testing the operations, (that's what I do, is all that crap for industry).
I was asked to look at an old inflatable (Zodiac) sailboat a few months ago that had leaky seams, (probably 15 yrs old at least).
This boat happened to be made with hapalon (not pvc). I determined that it was not repairable, all the seams had broken down, the adhesives had dried out, and couldn't be saved.
My understanding is more modern boats made from fiber re-enforced pvc then dielectric welded with mostly lap joints hold up much longer, (no adhesives are used at all, the pvc is bonded thermally with a quick reacting heat source , (ie ...dielectric, laser, microwave, hot roller, etc). More recent rib and inflatable boats, ( Zodiac, etc) are made this way as well as back yard swimming pools, and inflatable hospital beds. Using mostly fiber re-enforced modern PVC's. Equipment made with these newer methods and materials should last much longer than stuff made even 10 yrs ago. Yea the materials and methods have improved in leaps and bounds so what was true ten years ago may not be true now. Plus the new fiber re-enforced materials are nearly indestructable. The sparkle swimming pool guys actually carry around a patch of their pool material around and challenge people to try and poke thru it with a knife, (I couldn't).
Hobie is very tech savvy and I'm sure they are using the most current materials and methods. Basically what I'm saying is an inflatable bought today is a totally different animal from what was available even ten yrs ago and near impossible to even puncture. Just look at the many RIB boats out there with the 40hp motors on them, many down here use them offshore. I don't think you can punture them easily, or need to worry about the seams which are all lap welded thermally.
I haven't looked at Hobie inflatables at all so I don't know much about them. Next time I go in the dealer I'll check them out and report back.
Hope this helps
FE
PostPosted: Wed Nov 01, 2017 6:58 am
In industry a lot of CSM (hypalon) is used on the higher end stuff, (like high end rib boats). And a lot of my customers are moving more to TPO's ( mostly auto companies). I'm not involved at all in the inflatable boat and kayak industry. Most inflatable boats, and rv roofs, and car floor mats are done by sheet extrusion, (not my industry), though I try to help out with new material development for those industries, ( that's what I do). It's not my area of expertise, (my area is mostly injection molding). Can't really help much.
FE
Edit: It's my understanding Dupont exited the Hypalon (csm) market about 7 yrs ago, I don't know where current supplies come from. Perhaps their recent merger with Dow chemical will breath new light into the industry. My wagon is hitched to exxon/mobile more these days), and the big push that I'm seeing in the industry is TPO based, and enviornmental friendly high performance materials like our THRIVE plastics ( the greenest material available today), and combinations thereof. Basically nothin to do with inflatable boats, but I can deliver things like center consoles, and most interior and structural components in cars at half the current cost with 10-15% weight savings, (that's mostly what I do). Kayaking and sailing are my hobby.
PostPosted: Wed Nov 01, 2017 8:50 am
But several Hobie reps are saying to toss an 8 year old and sometimes younger PVC inflatables into the recycle shredder.
To be clear... for an 8 year old boat, we simply will not repair here or cover under warranty. They can certainly try alternate repair methods.
cron
