It is currently Tue Aug 04, 2026 1:03 am
PostPosted: Wed Jun 13, 2018 11:55 am
We have a 2002 Hobie Mirage.
The drive spine wheel broke so I had a Hobie dealer rebuild it.
Little did I know, and the dealer should of told me, that the new drive won't fit.
Am I now stuck with a drive I can't use?
Is there a modification?
Fresh: http://www.youtube.com/playlist?list=PLE02E23641B7FE360
Salt: https://www.youtube.com/playlist?list=PLeb5zOGDfoKlEPsMK5GBUOge_Qz5u2koH
PostPosted: Wed Jun 13, 2018 12:01 pm
Will fit.
For sure you would have to cut off the alignment pins and possibly shape the fairing a little, but this is all we build now. Older boats need minor tweaks. The alignment pin mod is noted in the drive manuals: https://static.hobiecat.com/item_attachments/80010001_80013011_80013001z52.pdf#page=2
PostPosted: Wed Jun 13, 2018 12:03 pm
mmiller wrote:
Will fit.
Oh good. Thanks!!
PostPosted: Fri Jun 15, 2018 7:45 am
mmiller wrote:
Will fit.
Would doing this mod make it so the drive couldn't be used in a newer hull?
Just curious.
PostPosted: Fri Jun 15, 2018 7:57 am
No... it will fit any hull after the modifications.
