It is currently Tue Aug 04, 2026 8:09 am
PostPosted: Mon May 13, 2019 5:34 am
The paddles that came with our odyssey tandem kayak have water inside the blades, and I can't find any way to remove it. I've seen other posts that talk about drilling out and draining, but I'm hoping for a solution that's less invasive. Is there an easier way to get the water out? I've tried shaking and standing them blade up, but neither of those options work.
PostPosted: Tue May 14, 2019 6:36 pm
You need to work out where its getting in or it will just come back. Dont know about hobie paddles but the blade to shaft connection is often suspect. Drilling a tiny hole and laying paddle horizontal with a weight hanging creating a low spot is best way of removing it (as you have probably read) then filling hole with a dab of epoxy. However you still need seal the original leak
PostPosted: Tue May 21, 2019 5:58 am
Thank you!
