It is currently Tue Aug 04, 2026 12:57 am
PostPosted: Tue Feb 11, 2020 5:09 am
Hi,
I've recently found that the Iddler Cable V2 of my Mirage 180 drive has broken. This Mirage 180 Drive is about a year old and had been repaired already due to a failure in the backwards mechanism.
Is that broken iddle cable covered by the warranty? Should I be concerned about the other cables? (the ones that have the chain attached) I'm unsure wether this is expected to happen in the other cables or if it's a single defective cable and I don't need to worry about replacing the other ones.
Thanks in advance
PostPosted: Tue Feb 11, 2020 10:06 am
Covered by the warranty. No problem.
PostPosted: Tue Feb 11, 2020 10:49 am
Thank you very much.
PostPosted: Tue Feb 18, 2020 6:36 am
Interesting since mine just broke as well and dealer said they tend to see other cables break before idler, so unsure if idler is susceptible to break more or not. Mine was 3 months past warranty and even though Hobie often covers things past warranty I did not even bother asking since it was a low cost easy fix. I bought an extra idler cable and soon will buy an extra chain.
