It is currently Tue Aug 04, 2026 3:29 am
PostPosted: Fri Feb 21, 2020 11:11 am
The spring action that holds the right pedal in the proper position on my 180 drive is broken. I am not sure what performs this function in the pedal.
Is this a reparable issue? If so what would I need to order to fix this? Do I need a new pedal or just some kind of a spring? I will look at it tonight but was hoping for a heads up before taking the pedal off.
To clarify, I mean that the pedal just rotates freely and does not rotate and hold place when I take my foot off of the pedal.
Thanks in advance.
PostPosted: Fri Feb 21, 2020 12:53 pm
There is a bungee cord inside the pedal.
Peel off the pedal pad to expose screws that will give you access to inside the pedal. The bungee goes through a hole in the pedal shaft. You should be able to re-use the pad, but if the glue is bad, you can use contact cement to reapply it to the pedal.
PostPosted: Fri Feb 21, 2020 2:53 pm
Thanks for the quick reply Matt! I was hoping it was something simple like you described.
PostPosted: Sun Mar 01, 2020 3:24 pm
I completed the fix (my bungee had broken). The hardest part was finding 1/4" shock chord (bungee). I tried a bunch of craft stores but eventually I found the perfect chord at REI. Just an FYI in case this happens to you.
Also, as Matt stated I was able to simply re-stick the pedal cover back on (it still had enough stickiness).
Thanks again Matt!
