It is currently Fri Aug 21, 2026 6:12 am
PostPosted: Fri May 22, 2020 6:48 pm
Just bought a new Passport 12 and my wife noted a dent in the forward hull. I have seen the video using hot water and air pressure but did not know if that would work at this location and with a thermoform hull. Any thoughts? Thanks
PostPosted: Sat May 23, 2020 10:56 am
Bummer! At least it is on the bottom and would have to effect on performance.
Hot water should work. These are polyethylene, so very similar to the roto-molded versions.
mmiller wrote:
Easy Dent Removal
Kayaks can be dented by various means, no need to worry, they are simple to remove. Improper storage, cart use, freight/transport, too much pressure on tie-down straps all can cause a dent in a kayak. We have the solution. Watch Jacques Bernier in the video linked below. Jacques explains the simple procedure that, as you will see, can remove even a nasty dent in the side rail of a kayak.
Dent Removal Video: http://www.youtube.com/watch?v=OpuIJzMotDg
Success Story:
