It is currently Fri Aug 21, 2026 3:42 am
 Post subject: polyethylene welding rod
PostPosted: Thu May 28, 2020 7:37 pm
Where can I purchase an appropriate welding rod to repair the steering crank bolt that is molded into the hull?
The steering crank seized to the bolt and has caused the bolt to spin from continued attempted use before realizing what was going on.
I've drilled out the steering crank axel from the hull bolt and have a replacement coming in the mail.
Now would like to re-secure the bolt.
Not sure of the name of the hull color - I'll call it "speckled grey" or "granite". It's an older Mirage Oasis.
Thanks,
Edward
PostPosted: Fri May 29, 2020 9:44 am
We can send rod at no charge. Order from your dealer. Would be solid while rod.
