It is currently Tue Aug 04, 2026 6:54 am
PostPosted: Thu May 10, 2007 5:25 am
Is the Hobie Sailing Rudder Blade much more responsive at low speed than the stock Revolution rudder?
I have a Prowler 13 with a KFS rudder on it. It works well when just drifting or at extremely slow speed. I wonder if the Hobie Sailing Rudder Blade will give me close to the same usefulness on my new Revo? If any one has any experience with the 2 rudders on the Revolution please speak up!
 Post subject: Sailing Rudder
PostPosted: Thu May 10, 2007 9:47 am
Yes. Simple answer. More blade and better response at slower speeds.
PostPosted: Thu May 10, 2007 2:47 pm
With the sailing rudder, if you're moving at all, you'll have steerage way. Whether drifting with a breeze or just coasting along, the large rudder will point you easily.
For the price ($23 ?) it's the single best value on the option list. I think you'll be very pleased with it. The only downside is that it's twice the weight as the standard rudder and requires a wiggling action to raise and lower. Once learned, it's easy to handle with the Twist & Stow lift mechanism. 8)
PostPosted: Fri May 11, 2007 4:59 am
Thanks for the input. That is Exactly what I wanted to hear!
I have one ordered!
PostPosted: Tue May 22, 2007 12:48 pm
You are 100% correct. Thanks!! :!: It should be the first accessory everyone gets.
PostPosted: Tue May 22, 2007 5:46 pm
where can I order one?
PostPosted: Tue May 22, 2007 10:05 pm
http://www.kayakfishingstuff.com/
