It is currently Fri Aug 21, 2026 6:15 am
PostPosted: Mon Aug 17, 2020 6:36 am
Hi - I just picked up an old '01 Mirage tandem - it has two square, flat surface mounting plates, ( either side of the transom behind the front seating position ), that look like a factory add on (same rivets). The base is black composite - but its inset with a square stainless steel plate ( 4 rivets) - with a knurled hole in the center that takes a screw ( sorry not sure of the screw size). Looks very much to be an adjustable mount - could be for a rod holder but since there is not other method of identification I don't know what i might mate to.
Any help appreciated.
Thanks!
CKL
PostPosted: Tue Aug 18, 2020 2:48 pm
It sounds like the previous owner added it for mounting something......fish finder, rod holder, Sidekick AMA kit or ????
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Mon Aug 24, 2020 1:44 pm
Exactly - takes a #10-32 screw ... but I am at a loss as to what "screw down" rod holder etc. it might have been used for - nothing I have come across so far mounts this way .
