It is currently Mon Aug 03, 2026 8:19 pm
 Post subject: V1 pedal adjustment pins
PostPosted: Wed Jul 28, 2021 9:30 pm
I just bought a used tandem Mirage and the pedal adjustment pins are shot. The balls in the detent pin are stuck in place.
I measured them at 1.5 inches and 5/16 diameter.
Are these the same pins as the GT, or is there an alternate pin? I don't want to use bolts like I've seen recommended.
Thank you.
PostPosted: Thu Jul 29, 2021 9:08 am
Yon can bolt them in place if you don't need easy adjustment. Or you can install the newer version. These are singles, so requires two per drive.
81236001 PEDAL ADJUST HANDLE ASSY BLK
or
81236002 PEDAL ADJUST HANDLE ASSY GRAY
PostPosted: Mon Aug 02, 2021 8:03 pm
Thanks for the reply.
These install on my original, un-upgraded V1?
Thank you
PostPosted: Tue Aug 03, 2021 10:33 am
Yes.
