It is currently Tue Aug 04, 2026 5:45 am
PostPosted: Tue Aug 03, 2021 7:05 am
I broke the cable on the chain drive and had to upgrade since they no longer make the older chains available. The new version of the pedal rubs against my kayak on every stroke making a squeaking sound. Not only is the sound annoying, however, I am concerned that it will eventually rub a hole in the kayak. Is there something that can be done? I love my old tandem mirage (I have 2 of them) and have no desire to replace them. They are built like a tank. It still looks like new even though I use it almost every day.
Thanks for any advice you can give me.
https://i.imgur.com/Cet3ink.mp4
PostPosted: Tue Aug 03, 2021 10:34 am
The drum is rubbing in the well?
PostPosted: Tue Aug 03, 2021 11:38 am
Yes. they are.
PostPosted: Tue Aug 03, 2021 4:01 pm
A little odd. Can you post a photo?
Image posting FAQ: https://www.hobie.com/forums/viewtopic.php?f=21&t=12574
PostPosted: Tue Aug 03, 2021 5:49 pm
Sounds like the spine isn’t centered on the drum shaft or there is a gap between the spine and the drums.
Peter
PostPosted: Wed Aug 04, 2021 10:00 am
If not just off-center, maybe apply heat to the areas of contact and force them out.... then cool? You could file a little off the area of the drums that are contacting.
