It is currently Tue May 21, 2024 6:32 pm
 Post subject: replacing pedals
PostPosted: Thu Sep 23, 2021 9:55 am
What tool is needed to remove the pedal from the mirage drive? Do you use tool on the outside of the pedal or between the pedal and the drive? Pictures or a video would be helpful if available.
Thank you.
 Post subject: Re: replacing pedals
PostPosted: Thu Sep 23, 2021 2:17 pm
Most pedal shafts are not removable. If you want to remove just a pedal from the shaft, there should be a nut under a round cap on the outboard side.
