It is currently Tue Aug 04, 2026 4:48 am
PostPosted: Wed Jun 06, 2007 7:32 am
We purchased our Outfitter over the winter. It has been a lot of fun through the spring! We were told to store it on the side when not in use. We had no problems until the heat spells of the last few weeks. It was left on it's side over abaout a week and a half and when we went to us it we noticed the rear 8" hatch had warped. It is very difficult to close and lock, and does not seem to set completely in the recessed area.
I have two questions, is this fixable? And what is the proper storage method?
Thanks for any help!
PostPosted: Wed Jun 06, 2007 3:26 pm
Hi applezz and welcome to the forum.
Sometimes the hatch seal can get twisted making the hatch seat unevenly. With time and heat, this can warp the hatch.
Open your hatch and check to see if your seal is twisted. Once you get it straightened, apply silicone spray to the seal, twist handle and hinges and make sure all openings are clean (no obstructions). This should do the trick. Do NOT use a petroleum based product such as WD-40, as this can damage the seal.
Both hatches should be lubed with silicone periodically. It's also good to squirt into your Twist & Stow rudder to keep it working freely.
Boat storage has nothing to do with your hatches, but rather hull dents. As long as you're following the recommendations in your owners manual you should be fine.
Let us know how the hatch works out. 8)
 Post subject: Twist or friction
PostPosted: Fri Jun 08, 2007 9:49 am
Is it twisted or just some friction?
You can not fully rely on the twist-screw to seat the hatch evenly and they will seal even if cocked a little.
As roadrunner noted... clean and lubricate with silicone. In addition, use your palm to press the lid completely flat in the ring.
