It is currently Tue Aug 04, 2026 3:17 pm
PostPosted: Mon Jun 11, 2007 6:24 am
How deep does a scratch or gouge in the hull have to be before I should become nervous about it? No leaks yet, but I'm wondering if I should consider a preemptive repair just to be on the safe side.
I ran over something sharp (oyster, most likely) that left a deeper than usual gouge. It runs for about 6 inches in front of and up to the drive well. It didn't perforate the hull, but I'm wondering if I can expect a crack or stress fracture in that area in the near future.
Any similar experiences out there? Thanks!
Hobie Mirage Revolution
www.neflkayakfishing.com
PostPosted: Fri Mar 13, 2009 9:33 am
I have some pretty nasty gouges on the bottom of my hull from oyster beds. I would like to repair them. What are the options?
PostPosted: Fri Mar 13, 2009 10:09 am
The plastic varies in thickness. Maybe 1/8" or so.
Best to leave them alone. The raised material will act as a barrier against further abrasion. If you really have a problem... you could do some filling with a plastic welder, but this is not common.
PostPosted: Tue Mar 17, 2009 4:59 am
Thanks, Matt!
