It is currently Tue Aug 04, 2026 12:58 am
PostPosted: Thu Sep 15, 2022 2:13 pm
I was helping a couple of friends decide which Hobie Kayaks to buy after they got all befuddled searching the Hobie website. Some of the kayak details are scattered about and I did not see a good comparison table anywhere, though there is always the "compare models" feature. I created a summary table for them and by the time it was done I had half the kayak line in it, so I went ahead and added the rest of them. Man, things have come a long way since that first lone Mirage kayak was introduced!
I have attached the table as a PDF. Note that it is legal size (8 1/2" x 14") to fit on one page. You will need to zoom in if viewing on a display. If you see any errors or omissions just comment or PM me and I will make corrections. I will provide a new version for 2023 once the new model details start showing up.
https://drive.google.com/file/d/14PQbVFmAVY4cfkIM4mDz3f75c6Z7dV4-/view?usp=sharing
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
PostPosted: Fri Sep 16, 2022 8:21 am
Nice work!
PostPosted: Fri Sep 16, 2022 3:14 pm
Very nice and good to see them all in 1 place Thank you!
BTW Lynx seat cap is 275lbs
22 Lynx
22 Compass Duo "Liparus"
22 TI "Victoria"
PostPosted: Fri Sep 16, 2022 4:11 pm
Though I believe that to be the case, I could not find that figure on the Hobie website or in the manual. Where is the reference to 275 lbs? Or is this same seat used in another kayak model that does specify that limit?
Also... When the Lynx came out the press releases touted it as "stackable". I list it that way but the Hobie website makes no mention of Lynx stackability, but it does explicitly list that as a feature for the two Passport 10.5 models. Is the Lynx still considered stackable and does Hobie document that anywhere? I see folks stacking them and suspect this is just an accidental omission on Hobie's website.
Peter
PostPosted: Fri Sep 16, 2022 6:11 pm
Peter
I can't answer you on the stackable ? but as far as the seat goes, you are right on both parts. I have a Lynx and it says 275 on the very back bar of the seat. The compass duo has almost the same seat and it also says the same on the back bar of the seat.
I "believe" the Lynx are stackable because my dealer has the on the showroom floor that way and he was very good about making me aware of Hobie rules for storage- showing me a warped compass that was stored improperly.
BTW do you know the "storage rules" for the TI? I am considering saving up for one of those but don't have the garage space to store it totally inside.
22 Lynx
22 TI "Victoria"
PostPosted: Sat Sep 17, 2022 8:04 am
OK, thanks for that, will update seat specs.
As to your TI question, that is a much bigger topic than for this thread. Suggest you review threads in or post to the Hobie Islands - Transportation / Storage forum.
Peter
