It is currently Mon Jul 06, 2026 10:43 am
PostPosted: Tue Jan 03, 2023 1:11 pm
Just got a Mirage Oasis Tandem. The TRAX wheel frame plastic pieces on the vertical post hit on the inner side of the kayak bottom and not evenly around the bottom of the hole in the kayak. Seems like this could cause localized stress on the bottom.
Is this how the Hobie wheel frame is supposed to fit?
PostPosted: Wed Jan 04, 2023 9:25 am
The fit is not great on the Oasis and a few other kayaks. Some have used tennis balls (with holes cut to slip over posts) or a very short section of pool noodle (may need to wrap outside edge with duct tape to keep from splitting or wearing quickly).
I used the pool noodle approach for a bit then switched to a Railblaza C-Tug to eliminate having to lift the kayak to get the wheels in or out.
Peter
2016 Hobie Oasis with Evolve v2 rudder mount, Sidekick ama kit, Mirage sail kit, Garmin echoMAP CHIRP 42dv, bilge pump
2007 Hobie Outfitter x 2 with Mirage sail kits, large rudder blades
