It is currently Fri Aug 21, 2026 9:11 am
PostPosted: Sat Feb 04, 2023 10:32 am
What is best way to drill a hole thru the cassette plug to install watersnake TM? Should I spray in foam, and if so, how and when?
PostPosted: Sat Feb 04, 2023 2:41 pm
The material used in the cassette plug is quite soft and I would use a hole saw of the correct diameter.
The hole saw should be the type that also has a pilot drill for centering the hole exactly where you want it and to prevent wandering of the cutting blade.
I would think that spraying/inserting expandable foam is done after you have a tube/shaft in the cassette.
Make sure to use a closed cell foam that won't absorb water.
Dr.SteelheadCatcher
Warrenton, OR
