It is currently Fri Aug 21, 2026 7:39 am
PostPosted: Sat Feb 18, 2023 9:03 am
I'm wondering what techniques other people have tried for plugging old screw holes in kayak hulls. I have an Outback that I removed some hardware from and I've used silicone caulk in the past but without a backing it doesn't always hold well and doesn't look great. Has anybody tried plastic welding rods or anything else with better success?
PostPosted: Tue Feb 21, 2023 8:00 am
Yes and this form is full of information.
Use the search feature located in the top right header under your topic.
Dr.SteelheadCatcher
Warrenton, OR
PostPosted: Thu Mar 09, 2023 4:37 pm
One really simple way to contend with small holes is to simply put a bolt or self tapper into it, with a little bit of silicone for good measure. It may just end up looking like its supposed to be there anyway, and doing this isn;t just easier than welding, its usually tidier as well. If you can get away with it, this is a pretty simple workaround
Kayak Fishing Specialist: SLH
https://slhobie.com.au
