It is currently Tue Aug 04, 2026 5:52 am
 Post subject: Water in the Hull
PostPosted: Thu Nov 29, 2007 1:20 pm
The first dozen times I took my new Outback out in the Gulf, there was absolutely no water inside the hull. The last time I went out, the water was a bit rough and so it took about ten minutes to get beyond surf. Waves were almost continuously breaking over the bow as I passed through the surf. When I finished kayaking, I discovered several gallons of water inside the hull. I assume it leaked through the forward hatch while going through the surf.
Has anyone figured out how to make a tighter seal on the large forward hatch?
Thanks,
Bernie
    PostPosted: Fri Nov 30, 2007 10:19 pm
    Theres a dude outta San Diego that has a kewl site called watermanatwork.com
    He has a bunch of how to's regarding kayak fishing including modifying the hatch(i.e. sealing the factory gasket, installing hatch straps, and installing a second gasket (so you end up with gasket meeting gasket) )
    These how to's can be found here
    http://www.watermanatwork.com/KayakFish ... /Hatch.htm
    Hobie Mirage Revolution
    Ocean Kayak Prowler 13
    - Look ma no hands
