It is currently Tue Aug 04, 2026 7:09 am
PostPosted: Sun Apr 27, 2008 6:20 pm
I like to work on my Outback on sawhorses but found my yak unstable due to its curved bottom. I found that by mounting a plastic pipe on one sawhorse which feeds through a scupper hole the yak now sits up straight. The pipe is mounted to a threaded pipe base mounted on the bottom of the sawhorse's top. It's easy to unscrew the pipe and use the sawhorse for other things.
Parts
- 1 sawhorse with a wood top. The thickness of the wood provides stability to the pipe.
- 6â€
PostPosted: Fri May 02, 2008 2:26 am
mate, great idea. i am forever working on my sporty. on the trolley in the garage, never thought of the saw horse, nor the idea you have just shown. hope ya dont mind if i use the same get up. :D
fish long and prosper
may the fish be with you.
PostPosted: Wed May 07, 2008 10:51 pm
Please use it and when you make it better show us all!
 Post subject: Boat Maintenance
PostPosted: Mon Jun 09, 2008 10:07 am
hi Each
Keeping a Mirage 'stable' for maintenance can be done easily by taking the wheels off of the Trolley (the one with the solid golf cart type wheels) inserting the trolley frame into the yak and using straps/ties /whatever is easiest to fix it to a sawhorse. Much like yur man says but can be done almost anywhere.
Flintstone
Flintstone
