It is currently Thu Aug 20, 2026 9:03 pm
PostPosted: Tue Dec 29, 2015 11:47 am
Hi, I'm new to the forum but I already found some helpful info here. I couldn't find the answer I was looking for using the search function. I have a long crack in my fiberglass kayak and am using west systems epoxy, 205 slow hardener, and a fine-weave cloth for repair. My concern is that I'd like to make the repair in one shot even though it goes along the bottom and up both sides. Is there a trick to keeping the already-wetted cloth from sagging during curing? My gut tells me that taping some peel-ply to hold it up should do the trick but my gut is not always right. (If it were I probably would never have to repair anything!). Any suggestions? Thanks,
Mike
PostPosted: Tue Jan 05, 2016 3:13 pm
Have you considered turning it over so the crack is on the top and then gravity will hold the fiberglass cloth in place.
Check this article out:
"The Bottom Job - This Old Hobie" by Rick Buchanan on pages 12 & 13 of the Sept/Oct 2008 Hotline.
http://www.w1dm.com/projects/hotline/08-09-10%20HOTLINE.pdf
Tim
84 H16
82 H16
87 H14T
Tortola Sails: 115222
Blue Prism Sails: 88863
Clearwater, FL
PostPosted: Tue Jan 05, 2016 3:33 pm
Great suggestion! I assumed that I'd have to lay up fiberglass cloth on the inside only to hide the repair but I like your idea. Thanks,
Mike
