It is currently Thu Aug 20, 2026 2:50 pm
PostPosted: Tue Sep 06, 2016 11:06 am
Hello,
I found a hole in my outback right where the peddles sit. Worried about the torque applied when peddling. Is the spot repairable?
PostPosted: Tue Sep 06, 2016 11:40 am
I have had my Adventure Island repaired in the same spot! Not an easy fix, and it doesn't last forever, that's why they have changed the Mirage Drive receiver, to alleviate that issue! Mine has a hole once again, so I am going to attempt a repair with this http://www.jamestowndistributors.com/us ... mail090616 Their help line said that it will work well, by roughing up the area, and using Fiberglass Cloth as a base. You can buy the repair material and hot air gun from Hobie as well, and repair it yourself, if you'd like! Any questions, just ask!
2005 AI Blue hull (yep, only one ever made!) Prototype!
2014 TI Red hull
2002 MacGregor 26X PowerSailor 50 HP on the transom!!!
PostPosted: Tue Sep 06, 2016 7:57 pm
search the forum for drivewell crack and see if its same issue. In which case its an iffy fix at best
